Tail Gait window Problems
Leebow
I bought my Bronco and didn't check to see that the key, not the one that starts the truck, worked in the rear key hole. I just tested the window from the dash switch and assumed that the key he gave me was the right one. The key goes in the hole, but it won't turn. Any ideas on how to get a key cut so this very handy function works. Should I go to a locksmith or maybe a dealership?
yo LEEBOW,
As ELMO advised; and it will be less $ if you remove the lock cylinder from TG and take it to a locksmith;
from 96 Bronco Workshop Manual
Lock Cylinder, Tailgate, Bronco
Removal
Remove interior access cover panel.
NOTE: If glass cannot be raised, remove glass. Refer to Section 01-11.
Raise glass.
Remove lock cylinder retainer.
Disengage lock cylinder from switch.
Remove lock cylinder from tailgate.
Installation
Follow removal procedures in reverse order.
BobButtertone
