Rear window
Bronco Jo
kalispell Mt.
Hi, i was wondering how i can get my back window down. My back window blew out, so i was going to take the one out of my parts rig, but it doesn't have a rear window motor, and the window place said they would take it out of the tailgate if i could just bring in the tailgate with the window. And i was wondering if there is some way i could get it down.
My guess , if there is no motor in it, then it is propped up with something. Open the access panel and check.
Also, changing the window is an easy task.
1. in the down position remove the weather strip on the inside and outside.
2. remove the two end seals ( one ***** each)
3. with the access panel open remove the electrical connection to the defroster if it is there
4. remove the 4 nuts that attach the window to the regulator.
5. remove the window, carefully
digs
