Rear Window won't go down
Katie1978
I have a 93 XLT who's rear window just crapped out on me. I don't think it's the motor, because you can hear it working when you turn the key. The window is stuck up so all I have to work from inside the vehicle. Any ideas? Is it a gear gone bad? How does one replace a gear?
Katie
muddpuppy
goldsboro, nc
Katie
look i'm having window problems myself and from all the threads i've read here it could be your gear
first you need to take off the access panel to the tailgate and there are four nuts holding your window up.
they should be 7/16, a ratchet wrench is best imo.if you can get someone to help you it best also. remove the nuts to release
the glass from the actuator and remove the arms from the bracket on the bottom of the window. this will allow you to lower the glass. CAREFULLY lower it down and you should be able to open the gate. now... you can access the motor
thanks to steve83 this should help you also
http://www.supermotors.net/registry/2742/12689
good luck and hoped this helps
my name is mudd
73coupe
Wapakoneta,OH
time to crawl over the seat and remove the access panel
on my 95 window was stuck 3 inches down
an arm slider had caught in a rusted out track
had to replace the silders and 1 track
still available from Ford
also had to rewire from the dash switch back
several write ups on rewiring for the rear window on the site
I chose to install a relay and run the wiring inside
if I have any more wiring go bad along the frame rail the rest is going inside
If it is a rusted track two people one working the switch and the other handling
the window can get it down to lowe rthe tailgate
CAUTION
person with their hands inside the tailgate needs to be very careful easy to lose fingers
digs
