Just out of curiosity, is there a reason you seem set on running the 4.11's ? Those are going to keep the engine pretty far out of it's powerband. 4.88's are what you want with 38's and a 4.56 would really be a minimum. With 38' tires it's almost not worth the expense of regearing from 3.55 to just 4.11
As far as reusing parts from the IFS axle, I have no idea. Here are copies of the D44IFS manual as well as the Spicer internal & external hub manuals for the hubs used on the various D44's. Also use the D44 manual I posted on the 14th. Read up on the hubs & compare info, photos, drawings & part #'s. Never having swapped in a closed knuckle D44HD I honestly have no idea if the steering will bolt right up or not. If anyone on *this* forum has done it they're sure keeping quiet about it
/emoticons/
[email protected] 2x" width="20" height="20" /> When I did my coil-sprung D60 swap I had to make a new, longer pitman arm to get the full range of steering that didn't bind anywhere.
I really have no idea if the Sterling needs a new carrier or not. I know the D60 uses one carrier for *up to* 4.11 and for 4.56 & higher you need a new carrier. You'll also have to figure out if you have a new or old 10.25 (93' or newer) because if it's older than 93' you'll need a new yoke if you replace the gears:
"Ford 10.25" and 10.50" can all use the 10.25" long pinion ('93 and later) Ring and Pinions. However, 1992 and older have a shorter pinion and different yoke. If you are installing a new ring & pinion in a 1992 and older 10.25 a new style yoke is required." (according to USA Standard Gear at any rate)
As for the master rebuild kit that's really a roll of the dice. Might work out just fine without one or it might not. You're really not going to know until you get them under the truck & running. How long have those things been sitting ? If I *really* wanted to know I'd probably put them up on jackstands & set-up a small gas or electric motor to spin the pinion for a few days & see if it leaked anywhere, but then again I enjoy doing silly $hit like that to aggravate my wife
/emoticons/
[email protected] 2x" width="20" height="20" /> Check this page out for info on replacing your 10.25 seals:
http://www.thedieselstop.com/contents/geti...l%20Replacement
I doubt Jeff's carries parts for a closed knuckle *anything* much less a D44HD but it wouldn't hurt to give them a shout or shoot them an Email. If you're looking for a supplier have you tried the Spicer Parts link I posted in this thread back on the 17th ?
A leaf spring swap will definitely be easier, but you lose a lot of ride comfort & axle articulation (at least *I* think so, everyone has their own opinion though). I've done both coil & leaf D60 swaps and I won't do another leaf. Even with the 460 the Bronco is just too light of a vehicle to need or effectively use front leafs (once again, simply *my* opinion, I'm sure plenty of guys with leaf sprung Bronco's are happy with them. I just wasn't one of them) The hardest part of a D60 straight axle (or any leaf sprung straight axle for that matter) swap is dealing with the radius arms. Most 80-96 swaps I've seen used the 73-79 F150/78-79 Bronco radius arms and welded the C-bushing horns onto the D60 axle tubes. Either that or they fabbed up a wristed radius arm & used that with the same C-bushing setup
D44_external_hub.pdf
D44_internal_hub.pdf
D44IFS_manual.pdf
