Thanks for the come-back. The red and lt blue wire reads at best 4.70 volts at the plug at the module with the key on. The wiring diag. says it goes to the starting system. I believe it is the small wire on the center post (small post) of the starter solenoid. ( this is my quess, same color) When I pull it off the starter soloniod it reads 0.0 volts at the plug at the module. If I'm getting off course, please reel me back in. The engine cranks fine, yes the battery was low, and now thw white and LT blue wire reads 12.4 volts now that the battery is charged. I tried starting fluid before I used this forum, and it still wouldn't fire. I would start to pull my hair out but being over 50 there's not much left to pull. You did say it sounds like my voltage regulator is going.... any relation to the no spark ? Thanks again for the help and please keep it coming.
:wacko:
