genthree
Took all the guts out of the doors to prep them for paint. Trying to remove the wing window. Removed the 4 screws that hold the frame into the upper portion of the door. Got the bottom of the wing window off the spring loaded stud, but I can not get the weatherstip/rubber covered metal strip out of the window frame... Do you just pry it out? Does the portion of the frame between the primary window and the wing window come out?
This has got to be the most frustrating thing I have faced on this project..
