Will not start
jeffie_3
I have a 90 Eddie Bower. The ignition actuator broke.I replaced it. It still won't start. The rod on top of the steering column does move now. But nothing.Checked fuses and batter. Both are good. Any ideas?
Rons beast
The switch may need adjusted. First check if you are getting voltage in the red and blue wire at the solonoid while the key is turned to the cranking position.
If not then go to tying to adjust the ignition switch. You are looking for 12V from the red /lightblue stripe out of the ignition switch, when cranking.
If you have voltage there and didn't at the solenoid, the next check is the neutral safety switch.
Good Luck
As Ron advised; here is the Logic Table to test Ign Sw
Start R/LB - 32
Ign1 R/LG - 16
Ign2 Br/Pk - 262
Battery Y - 37
Accy1 Bk/LG - 297
Accy2 Gy/Y - 687
Proof1 Pu/Wh - 977
Proof2 Bk/LB - 41
& here is a simplified Neutral Safety Switch Wiring Diagram in in 87-91 Bronco & F Series C6
Source: by Chilton http://content.chiltonsonline.com/content/images/8828/images/88286w23.pdf
Switch Adjustment in 87-91 (from Factory Manual and the Ford Electrical & Vacuum Troubleshooting Manual (EVTM)
Source: by Broncobill78 (Dave) at Ford Bronco Zone Forums
http://broncozone.com/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=6659
BobButtertone
