Yo Grog,
Motorcraft short part number; 2D204, ABS Wheel Speed Sensor Housing (aka shield or mount)
Kit - contains 1 RH and 1 LH (Front) $58.92
See attached pic
BUT I DOUBT a new piece IS AVAILABLE ANYWHERE NOW.
Some friends have had local machine shops fab a housing. Or as exranger06 wrote in another Bronco site, "You don't need the sensor shields. The ABS will still work fine without them. I ended up destroying my shields when trying to remove them and I didn't bother replacing them. My ABS still works. I don't plan on ever getting new ones; I'm glad I don't have to deal with removing them anymore."
0r, for a YARD SEARCH on-line, I use;
https://www.hollanderparts.com
A yard that uses Hollander Interchange can search other yards and have it shipped.
The Hollander Interchange provides auto recyclers and auto collectors, rebuilders, and others with the easiest and most comprehensive solution for identifying interchangeable auto parts..." See their yard Directory @:
https://www.hollanderparts.com/SellerDirectory
Can select certain parts[, /B] including some Canadian yards.
Has Vehicle Pics for some vehicles
For a specific part, such as the housing, search for the next higher assembly, such as in this instance, the sensor or spindle.
or
http://www.car-parts.com/
Has Vehicle Pics for some vehicles incl. interior/dash, back seat, front & rear and engine bay
Bronco Used Part Search @ https://www.partshotlines.com/parts/ford/bronco/ with source, cost, yard and phone #
Concord Spare Parts @ https://www.concord-parts.com/
732-374-3872
[email protected]
http://www.picknpull.com
This is a Company name w/yard locations in various states
Can NOT Select certain parts
B&R Autowrecking, in CA, WA, NV, OR. "We have a fleet of over 60 trucks that deliver to business addresses all over Oregon and Washington. Outside of Oregon and Washington, we have daily shipping services. Contact Us for a quote."
"Will ship to their closest yard for $50 flat" by StemCellResearch", 2019
http://row52.com/Search
AND Want a Part? It's Easy...
1. You create a Parts Wanted Listing.
2. Parts Pullers respond with offers.
3. You pick the best one.
A Parts Puller gets the parts you need.
For obsolete parts by Ford long version pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
https://nospartsltd.com
And by a search function;
https://autopartsobsolete.com/truck-ford/
Find out if speed control, if equipped, recall work completed by a dealership. Call local dealer or register and view status @
https://owner.ford.com; or @
https://vinrcl.safercar.gov/vin/ ... have VIN ready.
"Summary: ON CERTAIN PICKUP TRUCKS, PASSENGER VEHICLES, SPORT UTILITY VEHICLES, AND MOTOR HOMES CHASSIS, THE SPEED CONTROL DEACTIVATION SWITCH MAY, UNDER CERTAIN CONDITIONS, LEAK INTERNALLY AND THEN OVERHEAT, SMOKE, OR BURN. THIS COULD RESULT IN AN
UNDERHOOD FIRE."
To confirm current status, use this guide by jowens1126 @
https://www.fullsizebronco.com/foru...ruise-control-recalls-repair.html#post6530073
note that the 93 recall is different than 94-96
1994 Bronco Brochure, Partial; Cover & Page 3; plus pics of EDDIE BAUER model accessories.
by BigRob at
1994 Ford Bronco Bronco Accessories pictures, videos, and sounds | SuperMotors.net
Free registration for some wiring diagrams (86 through 96) and Technical Service Bulletins, (80 through 96), same as by Ford @
BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
