truck blowing smoke when out on long drive
Lump1713
i noticed that my truck is blowing i guess it woiuld be white smoke only when i'm out on a long drive. i'm not burning any oil. and it also smokes from passenger side under the hood by the tranny dipstick. friday i had a hose spraying antifreeze all over the place. would this have anything to do with it? is it possible that i could have bad gas?
broncobob58
East Haven CT.
It sounds like an oil leak,If it doesn't smell like antifreeze it is more than likely an oil leak from the valve covers or possibly the lower intake.The valve cover gaskets usually dry out and leak over time.This is very common and when your driving the oil comes out and runs down the block and drips onto the exhaust causing smoke.If it is a bad oil leak you can usually see where it is coming from underneath.
