noahsdad86
okay guys I bought a cheap timing gun and changed my timing. I think i was about 10 degrees after TDC I think I moved it the right way to 10 degrees before TDC however the harmonic balancer is all worn and I can barely see the lines I could only be 5 degrees for all i know about how far inch wise should I have the line away from the pointer thingy. and should i see the timing mark before the pointer or after. Sorry for being a little green in this area. I drew a pic please see the attachment
