Timing question
johnnyreb
West Virginia
Are you able to do a compression test or cyl leakage check?
Those were famous for breaking valve springs, if it was on an intake valve it could cause your symptom.
They usually made a ticking noise, but not always.
Could pull the valve covers ad do a visual inspection too.
Hope that helps
Cheers
That would sound awesome!!
If she runs well, ignore the shaky vacuum.
Cheers
L/Bronco.it,s n a good thing we don,t live close together. You,d probably run me off. hahaha. How are you doing now? Good I hope. I go back for a check up in Feb. Has anyone heard from Meisk ? I hope he is doing good. Take care.
D
Dazman63
Canada
Cheers
It runs quite nice. It was the idle and vacuum that was throwing me off. When you increase the rpm’s the vacuum steadies out.
Thanks again.
Broncorich74
