Tilt Steering Column issues
MrMagilla73
Charlotte, MI
I have owned my 92 Bronco XLT 5.0 for just about 2 years and have just recently been able to start working on it. The steering wheel is "wobbly" so I did some reading on here about the best way to remove it, well I got it out and now I am trying to get the 2 T-30 bolts out that hold the tilt together... It appears the previous owner tried to fix the wobble by tightening the bolts that hold the tilt together... I have broke 2 torx bits and twisted one beyond recognition. Due to the aluminum housing, I am nervous about using heat.
Got any other suggestions?
yo M M!
WELCOME!
Some Torx sockets leave a lot to be desire in Quality terms. Sort of loike comparing Dollar Store screwdrivers to Craftsman, SPX or other hi Q brands
Try inserting PB Blaster penetrant first and tapping eac bolt slightly to help the blaster to..penetrate
This is how KC did it;
wrench and T 30 socket
Then you will have to fight the jaws on the underside of the column to remove the tilt piece. You will be left with this:
GL!
M
MrMagilla73
Charlotte, MI
PB Blaster worked very well! You were right about fighting those jaws... WOW!
I have the steering column tore down to the shaft and the bearings on the upper portion of the shaft (the tilt part) fell a part when I got it out of the housing. I am having a heck of a time finding information about replacement bearings... the shaft is still in good condition only showing a little wear in the area of the rear bearing, so I don't need to replace the intermediate shaft, I just need to put new bearings in it...
Help?>?>?>?
yo
Look in Ford's MC site @ http://www.fordparts.com/Commerce/CatalogResults.aspx?y=1992&m=Ford&mo=Bronco#Search
These are the Ford MC short parts numbers;
3517
Steering Column Bearing
Upper - large (50mm OD 40mm ID) $9.13
3517
Upper (small) 30.20mm OD, 19.20mm ID $8.30
Stop by your Dealer's parts and show them the diagram and bearing needed; our local Parts folks are great and will inspect parts too! As well as look for parts @ other dealer nationwide and in Ford warehouses.
Another source is; Our SPONSOR HERE Jeff's Bronco Graveyard
I thought Jeff's Listed the 92-96 Bearings, but I don't see it listed now; call and ask
here is the Column site(it is hidden in Interior Section and not part of the Steering Category???)
& w/vg info & pics!
http://www.steeringcolumnservices.com/ford/housing-bearings.php
Ford Steering Column Upper Bearing (Large)
This large bearing is not visible until the upper lock housing (Bearing housing) is removed. When this bearing disintegrates, it may damage the steering shaft. The upper bearings are usually replaced in a set. Dimension 2" OD
Our Part # BRG22
OEM # F4DZ 3517 C
Programming here in da Zone won't allow this image to be posted, so click to view.
http://www.steeringcolumnservices.com/ford/brg22-f4dz-3517-c-upper-bearing-large.phpFits Makes: Ford Cars & Trucks
Fits Years: 1992-2008
$21.50
Ford Steering Column Upper Bearing (Small)
The small upper bearing is often the first bearing to disintegrate when play develops in the upper column on Ford steering columns causing loosness. Most often when this bearing is bad, the lower and large bearing is also bad. Dimension 1¼" OD
Our Part # BRG21
OEM # F4DZ 3517 B
$18.97
Ford Steering Column Upper Housing Bearings & Retainer Kit
The Ford steering column often develops looseness in the tilt steering shaft and in the housing bearing. The steering wheel moves due to the small or large bearings being damaged, worn out or broken. The upper bearings are usually replaced as a set.
Our Part # BRG230
$89.95 Special Pricing
Also, they have brought back the Free parts break-out diagram! No Bronco
listed, so look @ F150 looks same as that by Ford above.
Bronc094
