yo Mark,
WELCOME!
As Skitter asked, Tell Us More!
Great Looking Bronco you have Mark.
Also, I had to looks at your SM site for more pics abd noticed you have a wiring diagram showing the
Inferred Mileage Sensor
Here is another diagram;
Inferred Mileage Sensor Wiring Diagram in 87-89 Bronco & F Seriies
TSB 89-22-08 EMW/IMS Applications
Publication Date: NOVEMBER 1, 1989
LIGHT TRUCK: 1985-89 BRONCO
1985-87 BRONCO II
1985-89 ECONOLINE, E-150, F-250, F-350
1985-88 RANGER
1986-87 AEROSTAR
MEDIUM/HEAVY TRUCK: 1988-90 F & B SERIES
ISSUE: The Emission Maintenance Warning "EMW" module operates a light that is located on the instrument panel. For 1985-87 model year vehicles, the light will display the word "EMISSIONS". For 1988-89 model year vehicles, the light will display the words "CHECK ENGINE". When the light is lit, it is indicating that the 60,000 mile emission maintenance should be performed. After the maintenance is performed the EMW module must be reset to zero time. Another type of module is the "
IMS" module. This module is not part of the light circuit and does not require maintenance. At a predetermined time, the IMS module directs the EEC IV processor to make a strategy change. A third type of module is the "COMBO" module. This module combines the functions of the IMS and the EMW modules.
ACTION: Refer to the following module application charts for the specific vehicle application and location of the different types of modules.
NOTE: FOR APPLICATIONS NOT LISTED IN THE FOLLOWING MODULE APPLICATION CHARTS, THE "CHECK ENGINE" LIGHT IS CONTROLLED BY THE EEC IV PROCESSOR. THESE VEHICLES DO NOT USE THE "EMW" MODULE.
1985 & 1986 MODULE APPLICATION CHART
APPLICATION - ENGINE - MODULE TYPE - MODULE LOCATION - SERVICE PART NUMBER
Aerostar - All - EMW - Left Of Steering Column On EEC IV Bracket - E5TZ-12B514-C (1000 Hr) or E5TZ-12B514-A (2000 Hr)
Ranger, Bronco II - All - EMW - Behind The Glove Box - E5TZ-12B514-C (1000 Hr) or E5TZ-12B514-A (2000 Hr)
Econoline, Bronco, F-Series - All - EMW - Bottom Of IP Left Of Steering Column - E5TZ-12B514-C (1000 Hr) or E5TZ-12B514-A (2000 Hr)
1987 MODULE APPLICATION CHART
Aerostar - All - EMW - EEC IV Bracket - E5TZ-12B514-C (1000 Hr) or E5TZ-12B514-A (2000 Hr)
Ranger, Bronco II - All - EMW - Behind The Glove Box E5TZ-12B514-C (1000 Hr) or E5TZ-12B514-A (2000 Hr)
Econoline, Bronco, F-Series - All - COMBO - Bottom Of IP Left Of Steering Column - E7TZ-12B514-A
1988 MODULE APPLICATION CHART
Ranger - 2.0L - EMW - Behind The Glove Box - E5TZ-12B514-C (1000 Hr) or E5TZ-12B514-A (2000 Hr)
F & B Series - 6.1L & 7.0L - EMW - Mounted in the IP - E5TZ-12B514-C (1000 Hr) or E5TZ-12B514-A (2000 Hr)
Econoline, Bronco, F-Series - 5.8L - COMBO - Bottom Of IP Left Of Steering Column - E7TZ-12B514-A
1989 MODULE APPLICATION CHART
Econoline, Bronco, F-Series - 5.8L - COMBO Bottom Of IP Left Of Steering Column - E7TZ-12B514-A
1990 MODULE APPLICATION CHART
PART NUMBER PART NAME
E5TZ-12B514-C EMW Module - 1000 Hr
E5TZ-12B514-A EMW Module - 2000 Hr
E5TZ-12B514-A COMBO Module
Resetting
- Turn the key to the OFF position.
- Lightly push a Phillips screwdriver through the 0.2 in. (5mm) diameter hole labeled RESET, and lightly press down and hold it.
- While maintaining pressure with the screwdriver, turn the key to the RUN position. The EMW lamp will light and stay lit as long as you keep pressure on the screwdriver. Hold the screwdriver down for about 5 seconds.
- Remove the screwdriver. The lamp should go out within 2-5 seconds. If not, repeat Steps 1-3.
- Turn the key OFF.
- Turn the key to the RUN position. The lamp will light for 2-5 seconds and then go out. If not, repeat the rest procedure.
If the light comes on between 15,000 and 45,000 miles (24,155-72,464 km) or between 75,000 and 105,000 miles (120,773-169,082 km), you'll have to replace the 1000 hour pre-timed module.
