Steering Trouble
mytoy
Hello,
I recently bought a 88 bronco. It does have a 2in lift on it but it was on it when i bought it. My problem is that is wont turn to the left very far, it turns to the right fine tho. what do you think the problem is? Please help!!!!!!
bronx94
Does it have steering stablizers? If so they could be offset and causeing the truck to only turn one way.
87Bronco351
Katy, Texas
Well one suggestion is set your wheels straight, and look under your truck at your pitman arm to see if it is straight if it is off to one side your steering linkage could be offset to one side allowing you to turn just a little but like i said this is just a suggestion i could be totally wrong. Also check your power steering fluid. also you said it had a lift, check if you have a steering stabilizer if you do that could be a problem.
Sufferedformula
