johnnyreb
I found out a way you can check if you are getting spark to the plugs. While inside the cab. Take a piece of wire and attach it to your plug wire and use a tester or if you have a gauge to test the voltage--to see if you are getting enough power. If you are like me--and it is NOT recomened--I hold the wire and if it getting good juice--it will make your arm ****. Like I said--it is not recommend because it can **** you. Shorten your heart/ The VA doctor chewed me out when I told her about it.
