I was just checking in to update. Thanks for the reply.
I figured my best bet was going to be removing the motor, since a couple of the sites that told how to replace the motor had the same instructions TAPE UP THE WINDOW (or it will fall). Ergo, I assumed I could move the window up if I removed the motor, then I could slap the bad motor back in to hold the window in place until the new motor arrived.
I taped the window in place, and set about removing the window based on the directions located here:
http://forums.bucknakedoffroad.com/index.php?topic=133.0
I was taken aback by the fact I was going to have to drill holes into the door to remove the bolts, but pressed forward. Apparently a previous owner already knew this, had a bad window motor(?) and already drilled the holes for me. (YAY!) The downside: one of the bolts (bottom) was missing already.
So, removed the final bolt and the motor dropped into the door. When I retrieved it (funny story on that later), the wiring harness had come loose on one side. (It was spliced in two places PER WIRE.) One of them (+) had pulled loose from a pretty crappy tape job.... which immediately got my brain turning. Since I had only tested the motor via the harness, I hauled the motor up to the battery, slapped it across the terminals and BOOOYA! I can now (try and) cancel my order to JBG... the motor was fine. I spliced the wires back together (in better form than before) and threw the motor back in. All is well.
Funny sidenote: While trying to remove the second bolt (the one that sits just enough out of reach that drilling a hole into the panel would be near impossible, I lost my ratchet. I scurried up to the local Ace Hardware (about 3 miles away) and picked up one of those extended reach grabby things for picking up hard to reach parts. (two freakin' dollars... they could have charged me 30 and I would have paid it.
Since I could see it by the drain port, that was an easy grab. Later, during the course of the repair, I dropped a couple more items down there (shut it!), but when I would go fishing blindly for them, I would come back with screws I hadn't dropped. Hopefully they aren't important.
