goalie00rich
Hey folks,
I have started to replace the window and door seals throughout my '88 Bronco XLT and have run into an issue. I've removed the old window seals/felts, put the new ones in place (as the video from Broncos and Parts Garage on YouTube) and now the window wont go up. There is an area that seems to be a pinch point where the window felts curve to sit onto the door/window seal/track, where the glass can't go thru. The motor seems to work a bit slower than before (with the old cracked dried out window felts), but this is to be expected with tighter seals. I purchased the entire kit from Bronco Graveyard. Has anyone had the same experience or ideas on what I can do? The window is cleaned thoroughly and I'm hesitant of using any types of lubricants in on the felts. Should I purchase new window motors?
Thanks
Rich
1988 Bronco owner since summer of 2023
Thanks
Rich
