Well, I consider it easy. The seal that the glass slides into on the top costs about $90.00 at LMC or Bronco Graveyard. There are a couple of screws to remove and replace in the seal but it pretty much pushes into the slot in the fiber glass.
The seals on the tail gate are easy to install, just be careful not to bend them.
I replaced all the weather stripping on my back window not too long ago. Its not to hard, my only advice is to REALLY clean any areas where adhesive is used to ensure it sticks properly. I'm just lucky i live in az where rust isn't much of problem, it allowed me to slack on it for over a year!
