regearing questions
BigGreenBronco
North Florida
hi i have a 95 302 dana 44 front and ford 8.8 rear i have 35inch tires i want to have a lil bit mor get up and g oi think my ratio is around 2.70 im thinking about changing it to 3.55 its my everyday driver what all do i need to by for the mechanic to install the gears?
wileec
Erie CO
If it is stock your 95 most likely has 3.55s in it, and I am sure with 35s it is a slow DOG. I have 4.56 with 32s and a 5 speed and can not imagine going back. I would suggest going to 4.56 if you are running 35s. You need ring and pinion for front and rear also a new carrier for the front, I think do not remember, Also a master install kit for both. How hard do you wheel? Might be worth looking at a locker if you would make use of it off road.
digs
