Rear Window
White90Bronco
I have a 1990 Fullsize. Is there a relay for the rear window switch(es)? If so, where is it located? My problem is my window going down very slow. It goes up fast. I was told to check the ground, too. I was also told that a relay might be getting hot, so if there is one I need to know where it is.
Thanks for the help in advance.
Casey
BLADE262US
Michigan
Nope no relay switch contacts may be getting bad though or helper springs on actuator may be broke or weak . :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
W
White90Bronco
Are the acuator springs easy to come by (like Autozone or similar store) or would I have to go through like a Ford dealership?
Sandoval_broncosauria
