Rear Window
White90Bronco
I have a 1990 Fullsize. Is there a relay for the rear window switch(es)? If so, where is it located? My problem is my window going down very slow. It goes up fast. I was told to check the ground, too. I was also told that a relay might be getting hot, so if there is one I need to know where it is.
Thanks for the help in advance.
Casey
W
White90Bronco
Are the acuator springs easy to come by (like Autozone or similar store) or would I have to go through like a Ford dealership?
