I know there's a lot of fuss about the rear window having problems, I did a search but didn't find anything that was directly to my problem.
Problem: Window goes down smooth but not up, almost like little power.
The latch switch was removed (opens when fully closed) because the key operated switch did not work so the drivers switch is my main one.
What can I do to get power? If there's a forum I missed with this info, direct me to it otherwise im open to ideas.
Also this is something I had in mind but didnt know if would work:
Get rid of the wires going from the drivers (master) switch and connected the two (purple in this case) directly to the motor wires.
