LabCab
I just purchased an '89 Bronco......has little rust and runs like a horse!
But the problem is the back window will not go down and so the tail gate will not open. I had a Ford dealer hook it up to a diagnostic (for free, thank goodness) and there are no electrical shorts. Fuses seem to be intact as well.
Took the back panel off from inside the vehicle and its obvious that someone had worked on it before since there was a layer of duct tape under the panel. Took the motor out, tested it on the battery and it works. Checked the wiring at certain points and I am getting power to the "up" mode but not the "down". So I figured it needed new wiring. Ran up to the autoparts store, bought some wiring to fix the issues and when I went to test the wires again before installing the new wiring I don't show any power to either the "up" or "down" mode. Arrrgggggghhh!!
Anyone got any ideas on what to try next?
