re; "...the setting on the multimeter to check for a current draw is 10 dca" correct
Have to have battery tested, although new since it is below 0.50A
May as well have alt checked for free too.
Parasitic Draw; Diodes inside the alt could be shorted, thus causing drain, but the it would still put out 12 Volts, and pass the Voltage Output Test, however it could not put out full current, and would fail the Current Load Test.Remove & Charge Battery and take voltage reading (should be around 12.6 volts). Disconnect alternator, then re-install battery for a day or so & then check batty voltage again; if no drain, then diodses are prob the issue. or Take alt it to a parts store where they can BENCH-test it for free. BTW, The voltage should be between 13.0 and 15.0 volts w/engine idling. by miesk5 at Ford Bronco Zone Forums
http://broncozone.com/topic/22079-battery-drain-when-off/
READ MORE
Possible sources of current drain are vehicle lamps (underhood, glove compartment, luggage compartment, etc.) that do not shut off properly.
Also a hung-up relay (contatcs fused together, etc.) can draw through the Fusible Links that are rated way above that parasitic draw rating. Typically, EEC Power and Fuel Pump
EEC Power Relay Location in an 86; "...On some 86's (like mine) you will find the EEC Power Relay in the cab to the right of the gas pedal...sorta where your ash tray would be..." Source: by Xris
Or, mounted behind the air filter box; pull em and check for draw again.
Also, I have some later year Alternator tests in my site @http://www.broncolinks.com/index.php?index=74
such as;
Measure voltage at B+ terminal on the back of the generator, Circuit 38 (BK/O).Is voltage at B+ terminal equal to battery voltage?
