fizz, I've added pics to the gear tech sticky:
http://broncozone.com/forums/index.php?sho...amp;#entry89950
That's like asking which is better, a manual or auto tranny. I prefer the Ford 9" for strength, since it doesn't have the weak C-clips holding in the axleshafts to the differential and the spot-welded axle tubes found on the Ford 8.8" axle. Most folks just run with what they have, especially on the later-modle Broncos with the VSS in the For 8.8". Both axles are used on 1/2-ton trucks and Broncos, and both could stand upgrading if running larger tires over 33" tall.Which is better the 9 inch rearend or the 8.8 rearend for strength wise.
