Please Help me get my beloved Bronco get back to factory standards,because the previous owner didnt take care of her! :barf![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
First off I see 2 empty holes in the throttle body,does any lines suppose to go here? And that empty bracket with the rust ring in the middle does the ground to something?
![GEDC0001.jpg GEDC0001.jpg](https://www.broncozone.com/data/attachments/19/19278-ac39a28e16241594f4f848e49949f81e.jpg)
Next there is a little black clip type thing under my sterring colunm,where would this hook up to?
![GEDC0009.jpg GEDC0009.jpg](https://www.broncozone.com/data/attachments/19/19279-8e8117fd7c822b5c212defc9a9054f55.jpg)
3rd, in the pass kick panel,we have a whole heap of wiring hack jobs. Notice the 4 pink crimp connectors at the bottom. Well those wires run under the dash in the middle connected to 2 relays(shown in pic 2). Does anybody what the PO was trying to do? If you need wire colors let me know.
![GEDC0002.jpg GEDC0002.jpg](https://www.broncozone.com/data/attachments/19/19280-a1d6850b9393f7a326d5a6f54562f682.jpg)
![GEDC0010.jpg GEDC0010.jpg](https://www.broncozone.com/data/attachments/19/19281-6f7d70b8bb712820239dcb7506ec0390.jpg)
Last we have a broken pink or peach color vacuum line under the hood. My diagram says it goes to the Air BPV from the SOL V(TAB).The PO had it hooked up to the EGR valve...:barf: Is the Air BPV the pump in the pass fender area the blows air out or the belt driven pump? If it does go the the belt driven smog pump,does anybody have pic of the location?
![GEDC0011.jpg GEDC0011.jpg](https://www.broncozone.com/data/attachments/19/19282-5f35403bc93f3b65a3c5722183f674a9.jpg)
