power windows to manual windows
You need to find a set of manual doors to pull the regulator crank assembly out of . It will bolt back in where your electric assembly is now . There are 3 if I remember right aluminum rivets that hold it in the door they are kinda big and if you drive the center steel pin through it you can easily use a chisel or a drill to knock the head off the rivet . I did this on my plow truck its not too bad a job the door is kinda confined space though be careful of sharp edges . :D /emoticons/[email protected] 2x" width="20" height="20" />
RBuffordTJ
Norris, SC
C
cory1014
Cory1014
North Carolina
thanks guys. after getting new door panels and puting in the manual regulators can i still use the power door locks by cutting and putting the buttons through the holes and fab up a cover plate or something? i've got a few ideas drawn up but any ideas are welcome.
RBuffordTJ
Norris, SC
You can buy new door panels that have power locks and manual windows, so you won't need to cut. I believe Bronco Graveyard sells them too.
Rick in Orlando
rcarm74
