Poweersteering converion
Gomer 1
bronco_AIR_CONDITIONING_001.jpgHello I have a 72 bronco sport Completely untouched, It has a mark 5 dealer installed air condtioning unit, I want to put a power steering conversion in it , It has manual steering now. BUT, the AC seem to be in the way where the powersteering is supposed to go. I will try to attach a pic, How can I get power steering without losing my AC It work pretty good!
Thanks for any input
S_bolt19
Colorado
Welcome to the board...
Ain't gonna happen with that York sitting there. The PS pump you will use, either a 73-75 Bronco or a "Canned Ham" saganaw, sits right there and uses the same bolt holes in the head & block. Your best option is to remount that A/C on the pass side so that you can have the space for the PS pump.
oleguy74
hope you get this!!!bought my 74 new w/ac/ps.find a 74 with mounting hardware bolts right in.ac mounts higher.try it.so easy even a cave man can do it. :))
79' Buckin Bronco
