OD light Flasing
lisalarina
Texas!!
Hi there, I have a 95 EB Bronco with the 5.8L and my overdrive light is flashing when I reach speeds over 60-65 mph I don't know what it could be because i'm not lacking any power or slipping the transmission. Any ideas please help i'm puzzled :wacko: Thanks
yo!
here is some info;
E4OD Transmission Control Indicator Lamp (TCIL) Malfunction due to a faulty O/D cancel LED Part #F58Z-7G550-A Source: by ATC-Distribution Group Inc. atcdg.com via web.archive.org
It is easy to replace & under $12.00 from local Ford dealer or a BroncoZone Sponsor; Jeff's:
E4OD Transmission Control Indicator Lamp (TCIL) Button & Cap (replacement part) pic Source: by broncograveyard.com
be ready to catch the switch/LED assy when prying it off; it is spring loaded..not much force.
ck fuses too; I need to look for my notes on what fuse blew due to a harness short @ bottom of steering column that affected the OD Cancel Light (it blinked randomly, no Trouble Codes or tranny malfunctions though) under steering column; think it was 6 or 7; in a 96, should be same for your 95
Which happened (Bad L:ED/switch) to Mr P too:
E4OD Transmission Control Indicator Lamp (TCIL) Troubleshooting Source: by Mr P (scroll down 3-4 way) at rv.net
or
less likely since it doesn't shift Hard
E4OD Transmission Control Indicator Lamp (TCIL) Flashing Diagnostic Trouble Codes 62, 628 and/or 1728 & transmission shifts hard for 90-96 Source: by Ford via miesk5 (Al M) at comcast.net
do a self test;
Self Test & Connector Location & pics, Bronco & Ford BEST PROCESS WITH DIAGRAMS! Source: by Ryan M (Fireguy50) at fordfuelinjection.com
if found; look @ the Three-Digit Codes
L
lisalarina
Texas!!
Thank you very much that helps a bunch......I now know what i'm doing on Saturday morning lol thanks again!!!!
yo!here is some info;
or
do a self test;
