JBronco
Hello Fellas I got an 88 351 Bronco. To start this story about 2 months ago my bronco just wouldn't start one morning, prior to that morning it was idling a little rough and very rarely it would miss a little when I would accelerate but it was very minor and almost unnoticeable and it had been that way for about a year with it never getting worse. Since it wouldn't start I have changed the plugs, wires, distributor and cap, fuel tank (mine had a small leak), in tank fuel pump, fuel filter, and ERG valve (erg was totally clogged and seized up). Today after completing all that I got some new gas and tried to fire it up. Oh I should have mentioned when it initially wouldn't start that it would just turn over and over strong but it would not start. So when I went to start it, it took a long time but finally it fired up. Once it was idling it was a rough idle and when I would give it throttle it would be very rough building RPMs and if i went over 2500 RPMs it would get real rough and start to backfire and if i held the throttle it will die out backfiring all the way till it shuts off. When I go to start it again it still takes several seconds of turning over before it finally starts. Well that is my problem /emoticons/[email protected] 2x" width="20" height="20" /> I hope I have given enough info for a more savy bronco mech to maybe give me some ideas on what to do next, a buddy of mine said maybe injectors but I hope that is not the case as I don't have the money to do those at the time. So any advice is appreciated. Thanks
