ylee
Hi all,
Ok bought my 1987 full size bronco on the 12 of Dec.2009.The problem is it will start with the key but the rod is not returning.So you have to pull it back with a pair of pliers.And if you don't the starter keeps in gauging.Also to turn off you turn the key off and then pull the Rod all the way up.The key switch is very hard to turn sometimes.(esp when cold out side.)Is it hard to re-build a steering column.or easier just to swap out for a used/good one
Also in a separate problem When your cruising at 30-35 mph.The truck lunges/bucks,Acts like its trying to die not getting fuel ect.....And only does it at those speeds.Runs great under load and At every other speed rpm range.thought it was the overdrive shifting to early but can shift down to drive and still does it.It's not a major problem just very annoying.
