Ignition switch?
Bronco Jo
kalispell Mt.
Hi, i was wondering if anyone could help me resolve my problem. For some reason i have to turn my key back in order to get my lights and heater to turn on, but the problem is is that you have to turn it back so far that half the time you will **** it. I already tried adjusting the switch part thats mounted on the lower part of the column, but that didn't change anything, i also tried replacing the lock cylinder. Do i need to replace that switch or What else is there to check? :huh:
50joe
Trenton NJ
You can try unpluging the electrical switch. Sometimes after years of use the plastic melts, and the terminals dont make the proper contact. (If thats the case wouldn't hurt to take a gander at all your grounds to make sure they are still in good shape.)
Motormouth2025
