ignition key lock
boader73
oregon
I first noticed something weird when i had to turn the key half a turn more to get it to start-it did this once more and then when i went to turn it off the key cylinder was real sloppy and would not turn off. i had to disconnect the alt and battery to get it to stop running. I was hoping someone could tell me where to start perhaps replacing the lock cylinder this seems to be the easiest fix or would that be a waste of time?
boader73
oregon
91 xlt with a 5.8 I was hoping i didn't have to replace the switch but just the cylinder. how do you add info to the signature? thanx for your help.
bidibronco
Norfolk Va
If memory serves me right, there is a switch behind the key cylinder that had the "spring back" on it. It's the part you feel kick the key back after you start the vehicle. I may be wrong and it may be a diff. set up but I know I've had thoes go bad on many vehicles. It's an easy swap if it's there. I hope someone can cuncur with this or say I don't know what I'm talking about.
79brnco
