I cant find it on here
Bronco_Willis
Edmonds, WA
I have searched and searched this forum over and over and probably ran over the problem. So if anybody knows the thread then please point me in the right direction.
My problem is this...I have an 87 bronco and my rear window doesnt work. two days ago it would drop the window three inches and thats it. Now it just completely doesnt work at all. I pulled the motor, plugged it back in and it doesnt work. The key switch is disconnected from the key port itself so I was manual pushing the switch. Could this be a bad motor, switch or a wire?
Again if you know the thread that talks about this problem just point me in that direction if you dont wanna waste your time on me
THANK YOU!!!!!!!
BroncoJoe19
New Jersey
THANK YOU!!!!!!!
Hey... Welcome to broncozone.
the front dash switch only works when the ignition key is in the accessory, or on position, and it is on one fuse.
The rear key switch is on an always hot circuit and is on a different fuse. For the rear key to work, the dash switch must be in the nutral position. (I think it gets it ground from there)
Within both circuits to the motor, there is a safety latch switch in the left tailgate latch. That is often a problem. Try pushing the tailgate in while operating the tailgate switch.
You may try to bring power directly from the battery to the motor to test it.
I'll look for some threads for you.
joe
BroncoJoe19
New Jersey
wiring diagram
http://broncozone.com/forums/index.php?s=&...ost&p=76186
Diagram for front dash switch
http://broncozone.com/forums/index.php?s=&...ost&p=71393
ENtertaining thread on how to get front switch out
http://broncozone.com/forums/index.php?s=&...ost&p=73726
I fairly concise thread.
http://broncozone.com/forums/index.php?s=&...ost&p=72599
Searching is a lot easier after one has participated in enough threads.
Don't be afraid to ask questions.
joe
BroncoJeff
fLoWmAsTeRs=RuMbLe
Polk City, Florida
THANK YOU!!!!!!!
Hey, If it ends up being a bad motor, let me know, I may have one for sale :D /emoticons/[email protected] 2x" width="20" height="20" />
J. Hartle
Shadow_D
Schenectady, NY
These motor will work WITHOUT any load on them... I.E. They will work fine out of the truck because they aren't trying to move the window. The correct way to test the motor is to LEAVE it in the truck (mounted in place) and use wires you run from the battery to the back of the truck. All you need to do is unhook the wires to the motor and touch the wires you ran from the battery to the motor connections. If nothing happens first time you will need to switch the wires...
