Help!
bettybronco
i have a problem gentleman...my tailgate switch inside works...my key switch does not...i tested the wires into the tailgate and i have power only to the yellow wire(defrost i think). my fuses are fine so where should i check for the constant power? i have no power locks or lumbar or all wheel drive....so now im stuck....should i just rewire it to the battery?
more a pic & info by Steve
http://www.supermotors.net/getfile/517069/...e/tgswitch3.jpg
"Tailgate Switch Paddle
When the tailgate lock cylinder is turned, this paddle arm swings around & presses the appropriate switch button..."
often they wear out
Ground for the motor connects up front, & at rest runs from there through both switches & both wires to the motor.
-When either switch is operated, 1 side's ground is disconnected & replaced by hot.
-Ground for the motor is not connected to it's case, but supplied through the wires.
-There are seperate 2 power sources & 2 fuses for positive. 1 for each switch.
-The same 2 wires are used throughout for both up & down (Polarity is reversed by the switches).
bettybronco
well when my tailgate is closed i can open my window from the inside switch....i just cant use my key switch....i cant seem to find the tailgate switch that tells the truck when its open either...where would that be?
The tailgate key switch and safety mechanism is all one assembly behind the outer skin.
bettybronco
but im not getting any power to the switch itself...and that should be hot when thge truck is off right?
bettybronco
Thnxs....ill try tomorrow and respond with results!....thnx for everything btw!
