Help with Window Removal, tailgate, stuck down, no motor
Linney
Oregon
Hi! My 1996 Bronco.. tailgate window is stuck down. Motor is bad, I've tried jumping it directly, there is no motor function at all. I need help with GLASS removal. I've tried everything to get the motor to budge, no avail. The only way I can replace the motor is by removing the window... but how? Ive watched every video about switches and wiring and jumping the motor, I am passed that they all failed. I must remove the glass and can't find a single video or forum about the glass removal in down position. All I’ve found is to magically remove the 4 bolts at the bottom, which is impossible based on their direction, I can remove the nuts but not the bolts.
L
Linney
Oregon
Here are pictures of the bolts I can’t figure out a way to remove
Do you have the access panel off the inside of the tailgate? I was thinking you could reach the motor bolts there. Need to find a picture.
Those bolts you posted, you can remove the glass like that, but those are not always bolts, they might be rivets.
johnnyreb
West Virginia
Also hope you have a table close buy to lay the glass on. Hopefully you have someone to help take it out too.
Timothyfugate
Roseburg oregon
I beleave if you disconnect the motor you can push it up by hand but you need something to support the window while tail gate is open you can I have done this little peace of advice if you change one motor change them all T.F
sue
