B-Co Kid
- Joined
- Oct 14, 2010
- Messages
- 235
- Reaction score
- 8
Heater core is not connected. It is looped at the water pump and blocked off. I never heard of burping the cooling system. May give it a try.
Do you mean that you have a loop of hose going from the pump heater port to the head return port?Heater core is not connected. It is looped at the water pump and blocked off. I never heard of burping the cooling system. May give it a try.
That's a pretty engineThe fan shroud is in place and in tact. I modified the fuel plumbing,
So the steel braided line in the original pic runs from fuel pressure regulator to the carb
Inlet (see pic below). The smaller black hose immediately to the left of the radiator hose, runs from the carb to the vacuum advance canister on the distributor. I will swap the the hose on the
water pump to the correct configuration today, and post results!
