gears wont release
missie
Can anyone please help me? I had my bronco 11 towed in this morning, thank god I was only a few miles from home. Here goes, when I pulled away from stop sign and shifed in 2nd gear it wouldnt do anything, it was just as if it were out of gear. I pulled over and couldn't get it to release in any gear. Please help!! [-o<
M
missie
Maybe your linkage came loose or came completely off :unsure:
28049[/snapback]
I don't know. I found shreded metal that came out of my exhaust, could this be the clutch or any thing to do with the cluch? :((
No,
Can't imagine metal coming out the exhaust, on an engine that runs..?? May have a muffler colapsing..?
BTW-- this is a stick shift..? May need to Insp. the linkage attach points on the LH side of the trannie. Shift by hand....get in & push in clutch & start eng. slowly let out clutch to see if you move.
If it's an auto-trans, it may have a blown torque converter.
M
missie
Sorry, I made a mistake, the shreded metal came out from under the bronco not exhaust, hey I am a woman lol :wacko:
M
missie
I had a new clutch put in my bronco11 and that fixed the problem. Well after the clutch it shifts just fine, now I have a new problem. Let start by saying my ex-husband installed the new clutch. Now it stalls on me and when I come to a stop it dies, but it does start back up as long as I have my foot on the gas petal. Some time it wants to stall at 35miles per hour or less. This never happened before my ex installed the new clutch. I have accussed him of doing something wrong while putting the clutch in. PLEASE HELP???? :((
yusuebronko2_86
San Antonio TX
well.... as a victim of b2 pains, maybe you should check the throttle pos. sensor, the map sensor, etc.
also, what kind of tranny is it exactly (mazda, mitsubishi tk-4, tk-5) and what gear are you in at around 30-35 mph?
M
missie
:eek: /emoticons/[email protected] 2x" width="20" height="20" /> Thank you for the advice, I think I may have found the problem. The coil wire kept coming off, I think I have it fixed so that doesn't happen anymore, and I also replaced the pcv valve. It hasn't stalled or jump and ****** since I did that. I got my fingers crossed.
digs
