Engines
79bigbronco
Calgary, Alberta, Canada
i used 67 tbird 429 mounts with an adaptor plate, 2 of the holes line up , the 3rd is out about 1/2 an inch. I also had to use a fenderwell exit header on the pass. side to clear the starter, a manifold may have enough room.
TX_BEAST
waxahachie texas
since you still do some trail riding a good mid range cam would work out alright(somewhere between 260-270 deg duration) intake headers.
L&L sales motor mounts that will bolt it right in place with no problems they also make the headers. you can get them at www. broncograveyard.com
drubbz
