460 Saginaw bracketry
muddrivermike
Texas Arp
Hey everyone. Trying to get some help here. I'm gearing up finally to start building my 78 460 my 78 bronco.So I'm collecting parts before the block work. Here's my dilemma. I keep looking around online and can't get a concrete answer. I'm gonna be running my square York ac compressor. No problem there. My issue is I can't seem to find exactly what I need to run the Saginaw pump. I found a diagram with the setup and pics online. But the couple part numbers for the bracket that comes off the water pump to the pump, I keep finding slight differences. One bracket is more flat, another has a slightly higher side where it meets the water pump, ect. All under the same part number. Either way I need whatever is the correct brackets. It'll have a spacer where it meets my York mount to the head, the one that mounts to the pump, and the one from that pump bracket to the water pump.. online says A 80-87 E350 with a 460 is what it would come off of. Anyone have a lead on this? I'm gonna include some pics of what I "THINK " I'm looking for. I'm NOT running that pos Ford Thompson pump. Has to be the Saginaw.. thanks ahead Mike
Maybe someone else will know better, but nothing ever seemed to fight right when it comes to PS on those 460 trucks. You probably have to hold it up there and see.
I mean that looks like the bracket I used, but like you said it might be off.
My biggest battle was with headers there was no kicker brace on the back. Hard to get the belt tight and keep the belt running straight.
if I had it to do over I would convert to serpentine belt.
Yo Mike,
I tried to find a suitable Saginaw bracket off of 460 a Ford van, however I came to a?
Will try other sources.
muddrivermike
muddrivermike
Texas Arp
Yo Mike,
Yeah man. I found the set on eBay and the guy happened to have the pump which I really don't care about. But he wants 400 something dollars. He's smoking crack. So if I can find an 80 to 87 E series van in the junk yards around here which is slim I'll get one or come across it online for a better price. But sure if you happen to come across something let me know I'd appreciate it.
OK MIKE.
I was reading this "85 Saginaw P/S Pump Conversion @ http://chrisb.users.superford.org/Bronco/Projects/Saginaw_Swap/Saginaw_Swap.html
For the parts;
If a specific part isn't listed, search again for the next higher assembly.
Car-Part.com--Used Auto tParts Market
Can select certain parts
Has Vehicle Pics for some vehicles incl. interior/dash, back seat, front & rear and engine bay
Green Sales Company Main
1-800-543-4959 @
Main
Green Sales Company is an independent Ford and Lincoln-Mercury parts warehouse. Since 1957 we have bought from and sold to Ford and L-M dealers, service centers, hobbyist, and individuals around the world. Our inventory of 220,000 Ford/Lincoln-Mercury part numbers is 99% new original equipment covering 1950 to present. We also have a wide selection of reproduction items. All Ford product lines are represented. Essentially, we may carry anything a dealer normally would have stocked over the past 51 years.
We specialize in brakes parts; suspension; steering boxes; crash parts; weatherstrips; mouldings; gas tanks; water pumps; exhaust manifolds; switches; over 1500 fenders and quarters and items you just are not going to find elsewhere. Take the Green Sales tour to view a few scenes of our 95,000 sf. facility.
Peerless Auto Parts is now CLOSED
3541 Artesia Boulevard,
Torrance, CA 90504
(310) 856-4810 ‎
Autopartsobsolete.com sells New old Stock parts ( commonly abbreviated as NOS) , Original equipment manufacturer parts (OEM parts) and vintage aftermarket replacement parts sometimes referred to as NORS (new old replacement stock). .We do not sell any currently manufactured Reproduction parts.
Bronco Used Part Search @ Ford Bronco Parts | Used Auto Parts with source, cost, yard and phone #
Concord Spare Parts @ Spare parts for your cars, trucks and special vehicles
732-374-3872
[email protected]
Home | Pick-n-Pull
This is a Company name w/yard locations in various states
Can NOT Select certain parts
B&R Autowrecking, in CA, WA, NV, OR. "We have a fleet of over 60 trucks that deliver to business addresses all over Oregon and Washington. Outside of Oregon and Washington, we have daily shipping services. Contact Us for a quote."
"Will ship to their closest yard for $50 flat" by member StemCellResearch", 2019
Row52
AND Want a Part? It's Easy...
1. You create a Parts Wanted Listing.
2. Parts Pullers respond with offers.
3. You pick the best one.
A Parts Puller gets the parts you need.
By a search function;
Truck Ford
Pull-A-Part SEARCH INTERCHANGEABLE PARTS INVENTORY, @ SEARCH INTERCHANGEABLE PARTS INVENTORY
muddrivermike
muddrivermike
Texas Arp
So I found what I was looking for. I bought these off eBay. Everything I look up lines up with these. So the next things to track down are the stock column C6 shift linkage that goes from the column to frame to the trans.
Lana Kane
