Need some help troubleshooting the last problem in a longtime rebuild. The best way I can describe it - there is a spot in the pedal - just before the secondaries open, and just after they close, where I hear what sounds like poor combustion - kind of like a car that has too low a grade of gasoline, when the engine clatters and timing is off. I'm not sure that's what it is, but that what the rattle sounds like. The noise is faint a low speeds, but get's much worse (louder) at highway speeds. On the highway, it's right at crusing speed, so the only way to prevent the noise is to accelerate or decelerate. I can reproduce the sound anytime I want. Otherwise, the vehicle runs and sounds excellent. Smooth running.
Here's background on the vehicle:
This is a 79 Ford Bronco - bored out and stroked out the original 351M block to create a 400 - similar to the tech article I have read on this site around 2001. Changed out the original cam with Comp cam 32-206-3. Changed to TRW forged pistons 8.2:1 CR. Changed from original 2 BBl for a 4 BBL 600 CFM Holley. Changed to an MSD centrifugal advance distributor from original vacuum advance.
All of the internal engine work was performed by a reputable race shop in Lubbock, TX, so I have a high degree of confidence in it. Essentially they gave me a long block - the only internal thing I may have done was install the push rods and torque down the rocker arms.
Here's what I've tried so far:
I began to notice when I moved from TX to Oklahoma. But that may be just because I was paying attention more. I initially thought it had to due with a lower grade of gas. So I mixed a tank with racing fuel, such that I believe I had about 95 octane mixed. This did not solve the problem.
I tried to adjust the timing to get rid of the problem - this did not solve the problem.
I have change out to a bigger size jet in in the carb - this did not solve the problem. #1 plug in fact looks to be a little rich, but not bad.
I changed to the lightest spring possible for the secondaries - thinking if they came open sooner, and stayed open longer, it would alleviate the problem. This did not solve the problem.
I tried the lightest spings in the distributor, thinking more advance under load might help. This did not solve the problem.
So I've tried the less expensive things I can think of.
There's only one more thing someone has mentioned to me to try that I haven't yet. Go back to a vacuum advance distributor instead of the centrifugal advance. This obviously costs some $$ - so I though I'd ask if anyone has run into this problem before, or has any other suggestions.
Thanks in advance for any help. I am definitely a novice at this - this will likely be my one and only restore/rebuild - so don't hold back on even the simplest of questions.
