Driver window trouble shooting assistance please.
92broncoeb
Greenville sc
I have been reading up on some of the diffevent side window post that people have put up. Mine seems different than most. The windows goes down just fine but when it get to the bottom it clicks and keeps clicking like it does not know where to stop. The. When I put it up it goes up to different levels and stops but if I give it a little assistance by pushing up it will go the rest of the way up. A few times it has not stayed all the way up. It comes down a 1/4 in or less but if i hit the up button it goes right back.
I had a bmw that did something similar and it was because the regulator needed to be reset. Does the bronco have anything like that? does it even have a regulator?
Thank you for any guidance.
92broncoeb
92broncoeb
Greenville sc
Thank you, so it looks like I just need to get that window motor out and either rebuild it or replace it all together.
Correct, that is most likely the problem. When the bushing come apart they get lodged un different places. So no they don't all act the same.
As long as the glass seems solid in the door track it has to be the motor.
79' Buckin Bronco
