Door Lock Relay location
rlg50
Where can I find the door lock relay(s) for a 1987 Ford Bronco? Also, what does it look like? I've found a picture online for the RL2 and it's a small silver device, but I cannot find it in the Bronco.
yo RIG,
WELCOME!
Do you mean the actuator (also ref to as a motor) as shown in this 87 parts diagram?
Differences
The early lock motors are prone to water intrusion; both in the motor itself, and in the spiral BB mechanism, causing poor performance, high current draw, & eventual failure.
But by changing the connector & the mounting bracket, the later motor can be swapped in
Wiring Diagram in 87-91 Bronco & F Series
Source: by Chilton http://content.chiltonsonline.com/content/images/8828/images/88286w23.pdf
Actuator Replacement in an 86
Source: by Sixlitre (Malcolm H, Eddie Bauer) at http://www.supermotors.net/registry/4970/18427
Actuator Replacement in 87-96; "...One note first these directions are for the driver's side door. Please reverse the "left" and "right" directions for the passenger side door. Otherwise it is the same. Ok, first of all, take off the door panel. It is not necessary to remove the smaller panel underneath the main door panel. The actuator is on the lower left hand side. It is held on by a bracket that is riveted onto the side of the door. Do not remove the rivet!! This was my first impulse, but it is not necessary, and will actually cause a major headache if you do. It is a large rivet, and cannot be replaced with a standard riveting gun. The actuator snaps into the plastic bracket that is held on by the rivet. If you have a used actuator still in the bracket, it is helpful because you can see and feel how it is held on. If not, here is what it is like the actuator has two small "arms" which have rubber doughnuts on them, about 3/8" in diameter. These snap into the plastic bracket. The openings on the bracket point down. That is very important, since you have to know which way to push the actuator to get it out, because you can't see it. What I did was to put my right arm in the second hole from the bottom of the sheet metal, got a good hold on the actuator, and pushed hard, and it came out. It took a few tries. Push the doughnuts out one at a time, by using a diagonal motion. You probably will not have enough leverage to simply push it straight down. Then just slide the rod out of the hole, and pull the actuator out. Unplug the connector and you are ready for the new one to go in. On mine, one of the rubber doughnuts stayed in the bracket, and it is very annoying trying to get it out because the bracket turns around once the actuator is out. Try to avoid this. Now, before putting the new one in, grease the "threads" on the bottom of the rod, or it will probably squeak when you hit the button. I had to grease mine after the fact, so do this first. Unscrew the rod to make it as long as possible before putting it into the door, so it will hang low enough to get under the bracket. Then, plug in the connector, and make sure you have the wire routed on the outside (towards the outside of the truck) of the rod that goes to the door handle. The tricky part now is to get the rod into the hole. But, if you feel around while moving the lock up and down, you can find where this is, and best of all if you put your eye in the right spot, you can actually see it and get the rod right in. At this point, the actuator will be hanging by the rod, and will be plugged in. You just have to get it into the bracket. I had no trouble getting the doughnuts up into the bracket, so I was done! I just pushed it straight up into the bracket. Moistening the doughnuts will help make it easier. Then I tested the lock, and put on the door panel..."
Source: by JBronco
