Ozark Hauler
I started my new engine this am and got a not so good surprise . It runs like ***** !!!!
I've traced it down to Cylinder Numbers 2/3 and 6/7 .
I've replaced -
Long Block
Injectors
O2 Sensor
Wires
plugs (gapped @.045")
filters
cap/rotor
I've checked and reset
firing order
timing
plug gap
vacuum lines
harness connectors
I have 125 psi across the board (Dry)
I have "juice" to all injectors
I have fire to all plugs
All vacuum lines connected
I can't figure it out !!! and it's P!$$in' me off BIGTIME !!!!!
Called the local Ford Service Dept. and was told to swap injectors and see if the miss moved . Nope ! still the same cyls.
Dang Computerized POS
I'm whooped I have no clue and no equipment or guide to troubleshoot . Should I just capitulate and take it too Ford ?
Steve
I've replaced -
Long Block
Injectors
O2 Sensor
Wires
filters
cap/rotor
firing order
timing
plug gap
vacuum lines
harness connectors
Steve
