Hello, any help/advise is appreciated. My Bronco has a Dana 20 twin stick setup. I was helping a neighbor pull a stump over the weekend, and locked my t-case in low as well as the hubs, since then I can free the hubs fine and I got the t-case out of 4-low into neutral but when trying to shift the rear back into hi it won't go. With extreme pressure sitting at a stop transmission in neutral it will start to grind when trying to force it. I can put it back in low range. But I would sure like to get it back into high soon any ideas? One note I was on dry pavement when pulling that stump. And the t-case output shaft seal leaks a little not bad though.. It was doing that before. Could it be low on geear oil? So much for being helpful. Thanks for reading this.
