Cracked dash
scubscout53
Hixson, TN
As is obvious in these pictures, my dash recently cracked. I don’t want to cover it as I’m sure this will only get worse. Is there a source for buying new dashes? I’m afraid if I buy an old one, the same thing will happen.
Is the lower mount broken on the passenger side?
There was a fix for that from ford because it was so common. I would imagine that is why the dash broke there.
S
scubscout53
Hixson, TN
Looking underneath, I don’t see anything else broke. I assume I was looking at the right place, similar boats as what was holding the top up and there’s also a bracket close to the middle above the driveshaft that is in good shape.
This is a random picture I grabbed. This is a repair bracket and kind of an ugly one. But it shows where you should be looking for the broken bracket.
It doesn’t appear that I have this bracket, maybe I should have.
Could very well be that the end broke off, the plastic part the bolts to the door jamb and someone threw it away.
That is the one, Can't really tell if it is broken or not.
But from that bolt it extends under the dash.
They usually break just right at the edge of your picture where they start to get a little beefier.
In edit: If you lift on the dash right there and watch the bolt it is usually pretty obvious.
johnnyreb
West Virginia
What I did was went to Harbor Freight and bought some epoxy called HFT--Epoxy-Quick Setting. Park it in the shade and check it later on. As the dash stats cooling down. The crack will start closing to. Then fill the crack with the epoxy. If you see a crack starting--run down it. I put it in my Dodge about 5 years ago and its still holding. The epoxy costs about $2 oo
S
scubscout53
Hixson, TN
I thought about pushing it up and bracing it somehow after adding epoxy. Maybe using a torsion bar like I brace with in my truck bed.
johnnyreb
West Virginia
Welcome to the club
It might work. What I noticed in the morning. My truck was sitting in the sun and when I parked it in the shade--the crack started coming back together and that is when I got the epoxy and went down the crack and when it dried--it stayed. Its been holding about 5 years now. Anything is worth trying--beats letting it go and getting worse... Good luck.
Just use google for Ford dash repair bracket. There are a few different designs and prices from $25 to $300
Sufferedformula
