c6 questions
becker
I'm new to fords will a C6 2wd esily convert to a 4wd. also thinkin about buying a bronco that had 400 in it it has a Bad c6 so could i convert it to a 351 0r 302 with out having to get a new tranny such as an adapter or bellhousing
18415[/snapback]
Yes, a 2wd C6 can be fitted to a 4wd t-case, just need the correct tailshaft aqnd adapter. Ther is a difference in bolt patterns for a big block vs. a small block motor. So a C6 from a 400 or 351M won't bolt up with a 302 or 351W, for instance.
Elmomo
