Common sense perhaps but maybe taken to an extreme. The 351M/400 engines weigh 575lbs versus the 429/460's at 635lbs. You're talking about a 60lb difference, that's the weight of a small child if you follow that line of reasoning then you're also getting better mileage when you leave the kids at home or take off the cap and use a soft-top
Hah, ***** good point. I think it's more like 140 pounds, but it is splitting hairs. Depends what you need I guess, 400-500 hp is an aweful ot of power for most people, and the mileage of those engines is somewhere between 6 and 8 miles per gallon. If you take a 400, zero the timing gears, put a mild cam and decent intake and carb, maybe some flat top pistons you are around 300hp and over 400 for torque. More than enough to move a bronco easily along with 33" tires and a 3" or 4" lift, and get the mileage like I described, average of 14.5 miles per gallon. And that's with stock gears. Oh, and recurve the disttributor.
