axle codes
bigjohn
ga
hello kind of new to the bronco scene have worked on lots of straigtht axles before. but I need a lillte help. its a 2 parter
it is a 1980 bronco xlt with a 302 C6 trans.
1) there are no tags on either axles so trying to figured out what I got the tag code on the door jam is H2. can anyone tell what this is means.axle is giving trouble
2) if I got a axle from a 1989 bronco and found out they are the same ratio. I can just swap everything out ?
thanks for any info
bigjohn
H2 is Limited slip 3.50
in 1976-82
Gear Ratio (ring & pinion teeth count) Enter the number of teeth on the Ring and Pinion gears and click the "Calculate" button to view your results by jawsgear.com
Gear Ratio Determination; "...jack up the wheels, disconnect the driveshaft, rotate one wheel, and count how many revolutions the pinion yoke/****** makes..." Read More
Source: by Obi-Wan at http://www.jedi.com/obiwan/jeep/misc/gearratio.html
This is the reverse but...he applicable, he had a bad 8.8
9 inch Swap in an 88
Source: by kemicalburns (Travis L) - pics are @ at http://www.superford.org/registry/vehicles/detail.php?id=1725&s=16878#content
Travis wrote elsewhere; "...a fellow bronco guy set me up with a 9inch and we completed the swap on wednesday. total time was about 5hrs. the 9" swaped right in I even used the brakes from the 8.8 on the 9" but did need new drums. used the hard brake lines from the 8.8 as well. I would have to say that it was very easy as long has you have a second person to help. the drive shaft went on perfect. ive noticed that some broncos have a ****** attachment on some rear driveshafts that would require a new drive line.
BobButtertone
