axle codes
bigjohn
ga
hello kind of new to the bronco scene have worked on lots of straigtht axles before. but I need a lillte help. its a 2 parter
it is a 1980 bronco xlt with a 302 C6 trans.
1) there are no tags on either axles so trying to figured out what I got the tag code on the door jam is H2. can anyone tell what this is means.axle is giving trouble
2) if I got a axle from a 1989 bronco and found out they are the same ratio. I can just swap everything out ?
thanks for any info
bigjohn
BobButtertone
